Need TV Recommendation...50"->55"
Discussion in 'Archived Threads 2001-2004' started by DanSt, Jun 19, 2001.
  1. DanSt
    DanSt Stunt Coordinator
    Dec 19, 2000
    140
    Hey all!
    I have a friend that wants a big screen (50"->55"), but wants to buy it locally (ie. Best Buy or Circuit City, etc). He doesn't care about HD or 16:9 right now and he wants the price to be around $1500 give or take a few hundred dollars (preferrably take [​IMG] ). I don't know what to recommend that would be good quality. So I thought I would turn to the forum. Any help would be appreciated. Thanks!
  2. DanSt
    Dec 19, 2000
    140
    Hello? Does no one know about tv's here? You guys are usually great about Q answering. Please help on this one.
  3. William Ward
    William Ward Supporting Actor
    Mar 1, 2000
    701
    I'm also looking at getting a 50-55 inch TV. I'm exclusively interested in 16/9 and HDTV. My advice about getting a big screen as opposed to a WS is go for the wide. It'll make the DVD's look much better. Get a DTC100 and you've got HDTV!!
    If you're friend is dead set on a 4/3 bigscreen then I'd go for a Sony. I'm not sure if the bigger Sonys are in that range since the 36" WEGAs are almost $1500. Good luck...
    William
    Go Bucs!!
    MyDVDs
