BrianTwig
- May 1, 2006
I have pretty much settled on getting NHT IW3's for my front speakers and will get either the IW3 or IW2 for my surrounds. I will be using the SVS 20-39 PCi for my sub and a Marantz SR5600 or SR7500 for my receiver.
Here is my dilema. NHT does not make an inwall center to the best of my knowledge. So, what to do for a center. Would it be advisable to just get an IW3 and turn it sideways and use it for the center?
The NHT centers such as the M5, M6, Three C, SC1, etc... are not inwall, nor do I know how they will match up with the IW3s, and placement of them would likely be an issue. Plus they are a bit higher in price than I would like as I have a limited budget.
Thanks for the advise!
