1. The HTF Tapatalk application has been discontinued. Please see the thread in the Forum Help & Feedback area for more information.
Need speaker wire help
Discussion in 'Home Theater Projects' started by Mike Littrell, Mar 17, 2004.
  1. Mike Littrell
    Jan 13, 2004
    41
    I am having ceramic tile installed in our house, and have been wondering if it's ok to run speaker wire under it. I have no way to run my surrounds through the attic, so this seems like the only way. Has anyone done this? What are some other possibilities to get my surrounds hooked up?
    Thanks, Mike
  2. Wayne A. Pflughaupt
    Aug 5, 1999
    6,100
    33
    Katy, TX
    Wayne
    I see no reason why it wouldn’t work, as long as the tile people can deal with the leveling situation.
    Wayne A. Pflughaupt
  3. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    Can you run it where the wall meets the floor before the baseboards go back on?
  4. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    I would highly doubt that you could run it under tile. Any differential elevations in the floor below the tile causes cracking. Do you have a crawl space you can run it through?
    CJ
  5. KenA
    KenA Stunt Coordinator
    Mar 28, 2000
    109
    Massapequa, NY
    Ken Appell
    I also would aviod running wire under tile. The tile contractors should be able to deal with it (doubt they'll be happy), but you could have problems down the road if you crack a tile or if you need to rewire or reposition the wire. You are better off running wire behind molding or under the subfloor. You should be able to get under the subfloor before the tiling begins.
  6. Erik*R
    Erik*R Agent
    Mar 3, 2004
    41
    you can run semi thin wire under tile.. the bonding agent should be able to handle it. Thicker wire would be a problem. Id do what the others have said about the baseboards.. OR if absolutely necessary put the wire under the edge tile at the edge of the wall.
