Vanessa
- Jan 1, 2001
Ok guys, the situation is that the center channel on my Harman Kardon AVR65 has gone out and I'm looking to replace it.
Although I've been happy with the performance and sound quality of the H/K, this is the second time that it has needed repair. I bought it about 3 years ago as a refurb off ubid and it worked just great for the first two years. Late last year a rectifier blew and the receiver went into protect mode; $90 later, it was back in operation. At this point, I figure I need to get it fixed, but then I'm going to sell it. I have no confidence in H/K reliability at this point. (My brother has also had problems with his AVR70.)
I have been avoiding reading this section of the HTF as I didn't feel I really needed to upgrade and all the discussion would just make me think about all the new features, so I feel out of the loop on current receiver offerings. There also seems to be a big push on separates since the release of Outlaw's 950 and the Rotel 1066 - I'm not using "receiver" to exclude that option, just for simplicity.
What I'm looking for is a receiver that will keep me happy for at least the next 5 years. I will spend the money for quality (both feature and sound wise), but not to get wiz-bang features that I'll never use. That leads me to what I'd use it for and the minimum features I need...
I would say I'm equally into movies and music and I also use my receiver when watching TV (DPL2?). However, I just bought a house and am planning, in the next few years to make one room into a dedicated HT with a projector of some sort. I will likely keep a 2-ch setup in the family room where everything is currently set up.
My current speakers are Infinity RS-5 fronts, RS-4 rears, C-3 center, and HPS-250 sub. I am planning on (hopefully) replacing these with Adire 281s during the next year.
I have all the usual things that need connecting: DVD, VCR, DirecTivo, CD, Tape, and Turntable (have a preamp).
I would like it to have an IR control input, if possible, as my stuff is behind doors right now and controlled via Xantech.
Anyway, this is getting really long, and if you've read this far, thank you! If you have any recommendations to pass my way I'd appreciate it!
Vanessa
Vanessa
