Need some new headphones
Discussion in 'Home Theater Projects' started by Reid K, Jul 4, 2004.
  1. Reid K
    Reid K Stunt Coordinator
    Jan 16, 2003
    207
    I just recieved 300$ as a grad gift, and iam thinking of spending 100$ of it on a nice pair of noise cancelling headphones since I will be taking public transit to and from university everyday next year. Is this a reasonable budget or should I think of spending a little bit more? Also I really need some suggestions on good headphones to look at since i have no idea what I should look for
  2. dpippel
    dpippel HTF Premium Member
    Feb 24, 2000
    5,438
    1,741
    9,110
    Yoyodyne Propulsion Systems
    Doug
    Check out Head-Fi. Be forewarned that there may be way more info here than you want or need. Also be forewarned that visiting this site may cause your wallet to bleed profusely. However, if you want definitive info on headphones and headphone amps, this is where you want to be. Good luck!
  3. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
    As someone with close to 1,000 posts at head-fi.org, I will echo Doug's warning....you can kiss your wallet goodbye!! :b
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    If you had asked about "regular" headphones — i.e., transducers — this thread would have been moved to the Speakers/Subwoofers section. But since you're asking about noise-cancelling units, the thread has been moved to Accessories. The A/V Sources area is for discussing DVD and LaserDisc players, turntables/tonearms, VHS and D-VHS machines, DTV tuners/decoders, etc.
  5. Ray Tsui
    Ray Tsui Stunt Coordinator
    Mar 2, 1999
    60
    Sennheiser PXC-250 is a good set with active noise cancellation.
    If you want noise isolating ones and don't mind the earplug styles, check out models like the Shure E3C ($180 or so), or Etymolic Etymotic ER-4P ($220 or so) http://www.etymotic.com/ Both will provide excellent sound quality and very good isolation.
