Andrew:S
Grip
- May 19, 2004
Ever since I hooked up my new HT, the speakers will crack whenever I change the channel on my cable box and the crack is especially loud when I change from a normal channel to an HD channel broadcasting in Dolby Digital EX.
Setup is as follows:
2x Paradigm Titan (front)
2x Paradigm Atom (back)
1x Paradigm CC-270 (center)
1x SV PB2-ISD (sub)
1x NAD T753 (receiver)
1x Cox HighDef Digital Cable Box
Is this cracking normal? Is there a way to fix it?
Andrew
1x SV PB2-ISD (sub)
Andrew
