DaveD'
- Oct 26, 2003
I'm looking for a new projector for around $1k. For now it'll mostly be used for DVDs but eventually I'll probably hook up a hdtv signal. How well it performs in a semi light controlled environment(living room w/blinds) is a plus. I've done some research and the Sanyo Z2, Infocus sp5000/sp4805(many at avsforum prefer the latter), and the Panny AE500U are what I'm looking at right now. Any others I should check out or would you flat out recommend? Thanks
