need some help (1 Viewer)
TLawrence
Tyler Lawrence
I have an issue with my front speakers having a humm or a high pitch noice when im watching tv. Its really annoying and I would like to to stop if anyone could help me that would be great.
drobbins
Dave
Welcome to the forum.
We need a little more info. When you say front speakers, I am assuming that you have a receiver with surround sound? Do you have any equipment hooked up other than the TV? Is the hum there when listening to other sources? Is your TV and receiver plugged into the same outlet?
TLawrence
Tyler Lawrence
yes its a surround sound system. What do you mean what else i got hook up to the tv. I mean i have a xbox hooked up.
Joseph DeMartino
Florida
Joseph DeMartino
What kind of TV is it? Direct view CRT? LCD or plasma flat panel? Rear projection? If it is a CRT, are the speakers magnetically shielded? Try listening to them with the TV turned off. If the noise goes away, the problem may be interference from the TV itself. Try moving them further from the set.
Joe
socker_dad
