Need some help with some spyware...
Discussion in 'Computers' started by Jason Adams, Oct 14, 2004.
  1. Jason Adams
    Jason Adams Supporting Actor
    Aug 30, 2002
    633
    Roger Jason Adams
    For a week now, theres this nasty little bugger called "secboot" thats been showing up on Spy Sweeper, and Spy cant seem to get rid of it. So, how do I do it manually?
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    secboot is generally part of a backdoor Trojan. I suggest you do a virus check and see what it comes up with, run Hijackthis as well.
  3. Paul.X
    Paul.X Auditioning
    Sep 7, 2004
    8
    What folder is it finding it in?
    If it's in a system restore file you need to turn off system restore to get rid of it. You can turn it back on afterwards.
  4. Jason Adams
    Aug 30, 2002
    633
    Roger Jason Adams
    Well its in Windowssystem32. Sounds like its lodged in deep there.
  5. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    Try Adaware.. It works well to get rid of alot of different spyware.
  6. Jason Adams
    Aug 30, 2002
    633
    Roger Jason Adams
    Tried it. Its still there. Also there is this thing called XP_System, showing up, and theres also a folder in windows called inetdata, that comes back even when I go to safe mode and delete it.
  7. DaveNel
    DaveNel Second Unit
    Oct 13, 2004
    447
    You havent loaded any kind of XP software on your computer have you. Thats what its starting to sound like..
    Have you loaded any kind of drivers, firmware, applications or anything when the problem started..
    If you loaded software for XP on your system that has win2000 on it. Thats your problem.
  8. Jason Adams
    Aug 30, 2002
    633
    Roger Jason Adams
    Hmm...Well I did install something called ScrubXP, which erases the history file.
