Jonathan T
- Nov 6, 2002
I'm using WinID alpha to model a Stryke AV-12 in a sealed 2 ft3 cube. Using the SPL and cone excursion function, I've found that 250 watts will push the cone beyond it's Xmax at about 31.25 hz and the -3db point is about 43.15hz. Could someone also check this so I can see if I've getting the correct numbers.
