Need some help on subwoofer connection/placement.... (1 Viewer)
DerekM
Well, basically I've decided that there is only one place to locate my subwoofer - due to the room design, I'm forced to put it in a small nearby coat closet, unless I would like to use it as a coffee table (the thing is HUGE). All of my speaker wires are run inwall, and would like to do the same for my subwoofer cable, but am finding it hard to get a 50 foot cable. My main question is: will there be any signal degradation if I used 2 25' cables coupled together? I've found a pretty good price on a 25' dayton audio cable - but am open to any suggestions........anybody have one?
eathree
