Need some help hooking my PS3 up to my receiver (1 Viewer)
AmitT
Hi All,
Like the thread title states, I'm having a problem getting my receiver to pump out the sounds of whatever is playing on my PS3.
My setup is quite simple so I don't understand what I'm doing wrong, then again, I am a newbie at this.
I connected my PS3 to my tv with the HDMI cable and then connected the PS3 to my Sony STR-DE897 (yes, it's sorta old) receiver via the optical cable. It's hooked up to the optical input for TV/SAT on the receiver.
The video works but when I turn on the receiver and crank up the volume, nothing comes out of the speakers. What gives? What have I done wrong?
Thanks in advance,
Amit
Robert_J
Mississippi
Have you turned out the optical audio outputs in the PS3 menu? I think I read this same question in the last couple of weeks.
-Robert
Al.Anderson
Al
Also, make sure that the receiver's TV/Sat input is set to "optical". On most receivers it can be set to optical, coax, or stereo (red/white); if it's defaulted to something else you won't get sound.
chuckg
The PS3 default setting is to have the audio come out of the HDMI. Changing it to optical took me a while, since the instructions are not too obvious, and the menu item doesn't suggest much either.
Off the top of my head, there is a menu setting which has a submenu, but you may not realize there is a sub menu. Look through the settings menus, and seek one that has the sub menu pop open when you hit OK, X, or whatever.
(I know that's pretty vague, but I did this a few months ago. If I don't have too many bottles of holiday cheer tonight, I'll try to remember to post a better answer!)
mikezerby
