mrap
- Dec 22, 2012
- Mik rap
Hi,
I was hoping someone could help with connecting my pioneer vsx-819h to Samsung es7500.
I reCently decided to cut the cord, so there's no set top box in the mix.
I tried 2 options that seemed logical:
1) using the HDMI ARC ( audio reverse channel ) by connecting an HDMI cable to the tv in the HDMI 2 which is marked as ARC out and in the TV/Sat in slot in the receiver but it didn't seem to work. I wasn't sure if I needed to do anything in the receiver settings to make it work.
2) using the Digital Optical audio . I ran a digital optical cable from te optical out on the TV to the receivers AUX in but no luck either.
Any suggestions ?
Thanks for your help and happy holidays!
Any suggestions ?
