Need some advice
Discussion in 'Home Theater Projects' started by Michael:Z, Feb 22, 2006.
  1. Michael:Z
    Michael:Z Auditioning
    Feb 22, 2006
    3
    Hello every one
    In the next moth or two my wife and I are moving to Germany. we plan on taking most of our home theater equipment but have one problem, Germany uses 220 instead of 110, what I am looking for is a piece to convert 220 to 110 something like a power conditioner but instead a converter. Would like to get something with good quality but will not break the bank.If there is nothing like a power conditioner I guess a a good power converter. Second we are planning on buying an new TV. Right now we have a Toshiba 54 inch HD ready but would like to upgrade but staying in the 3000-5000 range with either same size screen or bigger. Any ideas.
  2. Eric Samonte
    Eric Samonte Screenwriter
    Mar 31, 1999
    1,318
    There should be transformers (which converts 220 to 110)available over there but I guess u have to use one that can handle enuff juice. Just plug ur existing power conditoner o that and I think ur all set. This is what we do in the Philippines. As for ur buying a new set, u probably be better off getting it over there.
    And welcome to the premier (if not the only)home theater forum in the world!
