Need some advice on picking between Toshiba/Sony...
Discussion in 'Archived Threads 2001-2004' started by Ryan Brown, Aug 25, 2002.
  1. Ryan Brown
    Ryan Brown Auditioning
    Aug 24, 2002
    2
    Hi, this is my first post here, though I've been a visitor here for quite some time. Here's my problem...
    I'm moving into a new townhouse on Oct. 1 and will be setting up a Home Theater in the finished basement. I've been looking for some time now, and have decided to get a 4:3 HDTV, as I feel it's the wisest choice for me at this time. Here are the two TV's I'm trying to decide between:
    Sony 53" KP-53HS30
    Toshiba 50" 50H72
    I'd like some opinions on these two if possible. I know that the Sony is $2199 and the Toshiba is $1799, but my fiancee works at Sears so I could get the Sony at 20% off, so the price difference is negligible.
    Is one: a lot better than the other, easier to calibrate, less likely to malfunction, better for standard sources such as cable/DirecTV, etc?
    Or is there any other TV you would recommend in this price range for me?
    Finally, I'm moving to Manassas, VA, a short distance from DC. Does anyone recommend a place to get a TV other than the obvious BB/CC/Sears type store? Though unless the prices/service are a lot better, it will be hard to beat the discount I can get through Sears!
    Thanks for any opinions/help given to me.
    Ryan
  2. Hugh Scrivener
    Hugh Scrivener Stunt Coordinator
    Mar 9, 2002
    70
    Both tv's will give you an excellent picture I'm sure. With the Sony you'll get a slightly larger picture but less control,calibration, etc. options than you'll get with the Tosh.. I've spent the last year on the debate of which RPTV to get. No-one wants to get ripped a new one, or feel that someone else has it better, for less...I ended up with a Sony KP51HW40. A wide-screen model, but with pretty much the same features as the one you're looking at, and am completely satisfied. I made this purchase approximately a week after I decided on a Toshiba. Impulse and a $700 savings ultimately made my decision...a decision based on a year of research. Take a close look at the features of each tv...this is where your debate will be decided, I believe.
    edit: If my girlfriend worked at Sears I would have give the Hitachis a closer look! Thats a nice picture...
