Need some advice on my non working Yamaha center channel speaker
Discussion in 'Speakers' started by JefferyL, Dec 15, 2003.
  1. JefferyL
    JefferyL Auditioning
    Dec 17, 2002
    6
    Hi there:
    I was moving this weekend and I accidentally dropped my Yamaha (I don't have the model no on hand) center speaker on my futon which has some wood on there. I plugged it in my Pioneer 710VS last nite and no sound coming out from it. There's no changes in any of my configuration on my Pioneer so my conclusion is that something must of happened to the speaker. Someone out there have any advice on more troubleshooting I can do?
    if this Yamaha doesn't work, does anyone have a rec on a replacment center speaker with my advent speakers?
    Thank you.
    Jeff
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    Well you must connect it to one of the speaker connections that is working....
    I'd take the driver9s) out, it probably just knocked a connection loose somewhere.
  3. kehi
    kehi Agent
    Dec 15, 2003
    35
    I would recommend taking out a driver and looking at the crossover and see if something is loose or disconnected
