Dean Cooper
- Oct 23, 2000
I'm finishing up getting the final items for my first DIY sub and I have a quick question.
Do I want a ported or sealed sonotube sub?
Here are the variables that go into the answer:
---This sub's main purpose will be for HT.
---I like deep clear bass with no distortion, loud is good but reference is too loud for me. So if the sub can reach reference its well within my needs.
---Size isn't an issue, I have a corner in my HT that’s just dying to be filled with a big 18"-24" by 6' monster.
---The driver I plan on using is the Adire Audio Tempest, which looks like its a little better suited for a sealed cab, but (as others have proven) will definitely hold its own in a vented cab.
---My room is 15' long 17' wide, has a large opening in the rear and a vaulted ceiling.
Right now I’m leaning towards the sealed cab because its simple and for a first attempt at something, simple is usually the best way to go IMO. But will I be missing out going with out the extra db at the low end the port would give me? Tell me what you guys think.
Thanks in advance
Dean
Thanks in advance
Dean
