Chris A H
- May 10, 2002
I have a very tight spot in my entertainment center (lower cabinet) in which to place a subwoofer (due to WAF). Can't be any bigger than 14.5"H x 16"W x 18"D. I have never had a subwoofer before, but I am assuming I will need a sealed unit with front firing in order to get the sound out of the space. And it should be magnetically shielded as well.
So far I have found only the following:
Titanic Vance D. Kit
Def Tech ProSub 200TL
Def Tech ProSub 100TL
others?
Possible options:
HSU VTF-2 (down firing, is this an issue in the entertainment center?)
Polk PSW303 (with "slot load venting" - what is that?)
Room is medium sized with a Klipsch 5.0 set-up & Marantz SR7200. Listen to 50% HT and 50% classical music. Prefer clena over "boom."
All opinions welcome! Thanks in advance.
Chris
others?
Possible options:
Chris
