Need recommendations for affordable 4 ohm surrounds
Discussion in 'Archived Threads 2001-2004' started by donovan_chin, Nov 30, 2001.
  1. donovan_chin
    donovan_chin Stunt Coordinator
    Aug 6, 2001
    150
    I'm looking for recommendations for any 4 ohm surround speakers. I would like to use them for my rears. Thanks in advance.
  2. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    Any particular reason you want them to be 4Ohm?
    If your receiver is rated for 4 Ohm speakers, it will certainly not have any trouble with 8 Ohm speakers. If you're worried about matching output levels, and you have a Dolby Digital receiver, you should be able to adjust relative volumes between the fronts and rears.
    That being said, the speakers from Ascend Acoustics are both great values and 4 Ohm loads.
  3. KevinGS
    KevinGS Stunt Coordinator
    Nov 21, 2001
    62
    Axiom has a great 4 ohm speaker, the QS-8.
    It's a quad pole, the tweeters fire outward on different angles and the woofers fire up and down.
  4. donovan_chin
    Aug 6, 2001
    150
    I was thinking of using 2 bookshelves (4ohms) in series instead of a single rear center channel. I tried putting 2 8ohm bookshelves in series (making it 16ohms). Unfortunately, it really changed the tonality of the speakers.
