Need recommendation on Affordable DVD player
Discussion in 'Playback Devices' started by Tim_, Apr 13, 2005.
  1. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    As you all know I just purchased my new set of MB Quart speaker and a Yamaha Receiver. Now I need advise on a good affordable DVD player that support SACD/DVD Audio/DVD+r/-r/RW, SVCD,VCD, CD Rom/R/RW. Basically all format for the best compatibility. Sort of do it all work horse, but less then $250.00, thanks all.
  2. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    546
    I think a Pionner 568a is what you are looking at in the new category. If you go to ecost.com though you could find plenty of Denon's that may fit the bill. I think the Denon 1600 also fits those specs (if bought at ecost).
