need recommendation for a sub under $400
Discussion in 'Speakers' started by Jeff_Garcia, Apr 29, 2004.
  1. Jeff_Garcia
    Jeff_Garcia Agent
    Oct 5, 2002
    46
    hi, im thinking of upgrading my subwoofer cause my cheap onkyo sub is just too muddy sounding, its annoying. i plan on getting either a velodyne CHT-10 or CHT-8. my basement is real small. its 18 by 10. my fronts are Klipsch SB-3. Im thinking that the CHT-10's might be overkill. im not really sure if they match well with my fronts. any suggestions?
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Definitely go listen to those velodynes as you may be very pleased with them. Also take a look at the low-end Hsu subs.
  3. Thomas Nichols
    Thomas Nichols Stunt Coordinator
    Nov 27, 1999
    115
    I would buy a dayton sub and save the 300$ for a sweet sub.
  4. greg baker
    greg baker Stunt Coordinator
    Feb 13, 2003
    165
    http://www.adireaudio.com
    For your budget you could shold consider the Adire Rava. It is a great sub for the money and at $399 it would fall into your budget.
  5. JohanD
    JohanD Stunt Coordinator
    May 22, 2003
    180
    He probably needs amplification for it too though? (my bad, I was thinking the sadhara)
  6. Edward J M
    Edward J M Cinematographer
    Sep 22, 2002
    2,031
  7. kevin-van
    kevin-van Auditioning
    Jan 18, 2004
    7
    adire rava is good choice, if you looking for something a bit smaller, creativesound.ca offers a smaller sub for $359, it uses adire 10" driver, and performs on par with a rava.
  8. Jeff_Garcia
    Jeff_Garcia Agent
    Oct 5, 2002
    46
    thanks for the suggestions. the adire rava sub looks sweeet. do u guys think a 12inch woofer would be overkill in a 18 X 10 room? and would a low frequency sub be worth buying with my front speakers? i have klipsch sb3, which are 52Hz-20kHz±3dB.
