Need projector advice
Discussion in 'Displays' started by BrianRS, Jan 30, 2005.
  1. BrianRS
    BrianRS Stunt Coordinator
    Jun 18, 2001
    57
    I think I'm going to have to jump on these new deals for the Infocus 4805 and 76" screen, but need a little advice first.
    1. My primary seating will be approximately 12' from the screen. I will probably start with the free 76" screen, but how large do you think I could go at that distance?
    2. Does the projector have to be ceiling mounted? I have an air duct that drops down about 12" from the ceiling about 10' back from the screen wall. Assuming the projector's throw distance would be more than 10', I would have to drop it down at least 12"-14" to clear the duct. Or could I just set the projector on my bar which is behind the primary seating area?
    3. I've never actually seen an in-home projector set up so I'm a little nervous about making the switch. Right now I have a 57" Toshiba with HD directv and DVD's on the Zenith dvb318. I love what I have, but would like the larger picture and am having a hard time resisting all the raving reviews and current deals. Any lst words of advice?
    Thanks!
  2. Pat Frank
    Pat Frank Stunt Coordinator
    Sep 5, 2000
    176
    We recently bought the 4805/76" deal. Your arrangement is almost identical to ours, and I can tell you that I have to zoom the lens out from the smallest setting about a quarter turn to fill the screen (at almost exactly 12' distance), so you've got some room to maneuver there. If you want to get a bigger screen that should be no problem at all -- we're considering upgrading to a 92" (16x9) screen.
    Our projector sits on a little cart between our recliners, about 3' off the ground. It's throwing upward at a slight angle -- the screen starts at almost exactly 4' off the ground -- but it looks fine even without using the keystone adjustment (but there is a slight taper on the sides which has me thinking about getting a taller cart).
    Make sure you get a component video cable. I elected for one in about the hundred-dollar range (25' length) rather than the super-expensive ones, and it looks great.
    One last bit of advice (since you asked) -- if you have a cheap DVD player you'll want to leave the 4805 in 480i mode, because it's deinterlacer is better than the one in your DVD player. I learned about this the hard way, and futzed around for at least a week before I got my fingers back here to ask about it. I imagine an expensive DVD player may be a different story, but you'll see what I mean almost instantly if you have a cheap one.
    Good luck!
  3. krury
    krury Auditioning
    Nov 22, 1998
    7
    The Infocus 4805 is very lightweight and portable. I project in my living room at 100" on a flat white wall using 12' component cable. It rests on a coffee table. I find it looks better projected at 100" rather then smaller. Compared to a $5,000 Epson Projector being projected on a Stewart Luxus Screenwall GreyHawk 100" ($1700) at the Hi Fi place it looked just as good.
    When I want to use it in my bedroom I plug in the 30' SVHS and watch tv or DVDs. It projects on the 76" screen I pull down in front of a 76" window, you would think it was customer made. Even at this short distance it looks fantastic. The 76" screen is a bright white, would have been better if it was slightly grey.
    I couldn't be happier with my first front projector. The blacks are black yet detailed, the skin colors are natural looking and everything is very rich in color.
    Overall I give it a A+, particularly considering the price.
