jcklaus
- Sep 9, 2006
- Josh
We have a room that is 53 feet long and do not want to mount a projector in the middle of the room from our very high ceilings. We're planning on having a 75" x 100" screen (125" diagonal). Do any of you have suggestions for high-end projectors that we should consider for such a large projection distance? Unfortunately, the light in the room is not ideal so we'd also probably need a projector good deal of brightness or that allows different lenses to help.
Thanks so much for your advice.
