Need Progressive Scan DVD Player Recommendation
Discussion in 'Playback Devices' started by DonM, Feb 28, 2004.
  1. DonM
    DonM Agent
    Apr 3, 2000
    35
    I just bought myself a new Mitsubishi HD65713 RPTV. I find myself using my old Toshiba SD-1200 DVD player without progressive scan. While it served me well it's time to upgrade the Toshiba player. It has been suggested to me to get a Denon DVD-910 or a Panasonic DVD-XP30. Is there any other recommendations out there in the bang for the buck category with good video performance that I should consider. I will be using this strictly for DVD movies playback. The Panasonic RP82 is highly rated but you can't get it anymore.
  2. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Don,
    Those 2 models use the Faroudja de-interlacing chip which is the best with video based material and a very few "problem" film-based dvds. The RP-82 and the Panny CP-72 were cheap players with the Faroudja chip, but nobody makes one with that chip for much under $300 any more.
    If you don't watch much video based stuff and don't mind occasionally having to manually turn the pulldown control to "film" you can get a JVC for less than half that price.
