Need Pin assigments on DIY VGA-component video cable (1 Viewer)
Gregg F
Grip
Hi
I want to fabricate a VGA-component video breakout cable to use on a iscan line doubler. I have the RGBHV 75ohm cable, BNC connectors with RCA adapters and a DB-15 VGA connector. What I need is the pin assignments on the DB-15 for the cable. Anyone have this info?
Gregg F
Grip
:emoji_thumbsup: Thanks a ton. Very, very helpful. Since I'm only outputting to PrYPb i will only have to concern myself with pins 1&6, 2&7 and 3&8.
Excellent.:D
Gregg
Bosshoag
