Need OTA HDTV tuner w/DVI w/o HDCP
Discussion in 'Displays' started by DanielGM, Jun 11, 2004.
  1. DanielGM
    DanielGM Stunt Coordinator
    Jul 15, 2003
    116
    I want to use an OTA HDTV tuner to output a DVI signal into my computer monitor. I understand that while my monitor most likely won't display a 1080i signal, it should display 720p. (If there is any other input on this it would be appreciated). The monitor obviously is not equiped with HDCP however; is there a tuner that can output a non-HDCP encrypted DVI signal? (cheaper the better)
    Also, can someone point me in the direction of where to choose the right antenna for receiving the most OTA channels, I live in Baltimore city on the first floor of a large apt. building.
    Thanks in advance
  2. Ryan FB
    Ryan FB Second Unit
    Oct 4, 2002
    277
    If you don't mind using a computer card to do this, the MyHD MDP-120 with DVI-D daughter card should do what you want, cost is around $350. You get the ability to record to your hard drive, and rescale 1080i so it displays properly to boot. [​IMG]
    Alternately, a Fusion HDTV3 card might work as well, but keep in mind it uses a software decoder (unlike the hardware decoder on the MyHD) so you'd need a pretty beefy processor to keep up. It's only about $160.
  3. DanielGM
    Jul 15, 2003
    116
    thanks for the offer Ryan, I would like a standalone component because I will also be using the tuner for other displays.
