Need Opinions on stuffing vented subs
Discussion in 'Archived Threads 2001-2004' started by James Slade, Jan 29, 2002.
  1. James Slade
    James Slade Second Unit
    Nov 20, 2001
    250
    I have done just about all of the work you can do on a sonotube sub without having the driver. If and when the Tempest ever shows up I will be done in a few short hours.
    Basically it is an Adire Alignment sub. So Would you or wouldn't you line it/stuff it and why?
    My preference would be to not line it, for ease of build and so I don't have to worry about the lining glue ever letting go. I am already planning a few more bigger sub projects in the near future, this one is just for fun.
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Stuffing a ported design serves a different purpose than in a sealed enclosure. In a sealed enclosure, the stuffing will make the enclosure "appear" bigger to the driver. It has to do with the way the air compressed inside the enclosure dissipates heat. For a ported design, stuffing, I feel, is mainly to "deaden" or damp the enclosure and to reduce any standing waves inside the box.
    Since you are building a subwoofer, the wavelengths you are dealing with are probably larger than the enclosure itself, therefore, there standing/resonant waves wont be a problem and stuffing it is not required.
  3. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    Yep, stuff a ported enclosure only if you are limited to the size of the enclosure (i.e. if you're not using the optimal enclosure size). I did this when I built Sunosub III (limited to the length of sonotube on hand), and the stuffing (using 1 pound/ft^3) returned an extra 30% of perceived volume (from 6 ft^3 actual volume to roughly 8 ft^3 of operational volume). I made this calculation by comparing the tuning frequency to the 'required' volume to get that tuning frequency vs. the actual volume (which should have returned a slightly higher tuning frequency for the enclosure, and it did - dropped the tuning frequency by 3Hz IIRC with the stuffing inside the enclosure).
  4. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    I'm a little confused on this one since Dan W recommended I put 8#'s of stuffing in the sonosub I'm building.
    Specs:
    24" x 72" sonotube
    dual 6" x 20" ports
    dual Tempests
    480L tuned to 17hz
    Should I double check with him on his recommendation for stuffing?? Is there an issue with standing waves in a dual driver sub that's 6' tall??? Thanks...Mike
  5. Travis G
    Travis G Stunt Coordinator
    Jan 6, 2002
    94
  6. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    How many poeple have stuffed thier Sonosub's and traditional ported box's with Fiberfill?? This would allow me to make a smaller box for a Tempest sub, then stuff it to make the "virtual-space" bigger.
