Dan Hitchman
- Jun 11, 1999
I'm installing a 7.1 channel home theater system for a neighbor of mine and so far they have picked out the following audio components (which should arrive Monday or Tuesday):
Denon 3802 receiver (with DTS-ES Discrete 6.1)-- using a cross over of 80 Hz. May add beefier power amps in the future for all channels (that's a-ways a way, though).
Polk Audio RT 55i (front and sides)-- 1" tweeter, dual 6 1/2" woofers.
Polk Audio CS400i (center)-- 1" tweeter, dual 6 1/2" woofers.
Polk Audio PSW650 subwoofer
Panasonic RP91K DVD-A/V player
Now we're debating the center back surround speakers...
Since there's a bit more space constraint in the back of the room they've narrowed the choices down to:
1)Polk Audio RT 35i-- 1" tweeter, single 6 1/2" woofer.
2)Polk Audio RT 25i-- 1" tweeter, single 5 1/4" woofer.
The difference in price is ~$90, not including tax. They're already teetering on the edge of their budget, but still want the most wide-range, coherent soundfield they can get... The system will also be for music and they like the DTS-ES music discs so far. They also love The Haunting in DTS-ES Discrete 6.1, which has a center back channel running at full force.
Here are the specs.:
RT 35i: http://www.polkaudio.com/home/specs....y=4&speaker=27
RT 25i: www.polkaudio.com/home/specs.php?category=4&speaker=26
Which model speaker of the two would you choose and why? I already know which pair I'd pick, but perhaps if there is a concensus, maybe the RT 25i's would work.
Thank you!
Dan
Stop HDCP and 5C-- Your rights are at risk!
[Edited last by Dan Hitchman on August 05, 2001 at 11:12 PM]
Thank you!
Dan
