Need mic suggestion for teamspeak
Discussion in 'Computers' started by Pablo Abularach, Oct 27, 2003.
  1. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
  2. Shane Bos
    Shane Bos Second Unit
    Jun 15, 2002
    256
    I use a Labtec mic that I paid about $20 cdn for and it works great. Of the 3 you listed I would probably go with the Plantronics.
  3. Pablo Abularach
    May 27, 2002
    526
    Shane,
    Thanks for your reply,
    I havent heard anything of labtec, but I search and found this two options,
    Labtec VERSE 524 DT $5.27
    Labtec VERSE 534 $7.91
    Do you think any of this two are superior or best options to the ones mention before?
    Thanks for taking the time,
    Pablo
  4. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    110
  5. Shane Bos
    Jun 15, 2002
    256
    The mic I use is similar to the verse 534 however it's black instead of white. It's probably just the older model.
