Need inexpensive amp
Discussion in 'AV Receivers' started by Andrew Pezzo, Apr 26, 2004.
  1. Andrew Pezzo
    Andrew Pezzo Second Unit
    Mar 17, 2003
    483
    I am looking for a 2 channel amp to power a second zone. Its going to be driving some small speakers that dont require a lot of power. The problem is I dont usually see low wattage 2 channel amps anywhere. Anyone have any suggestions?
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Adcom's GFA-535 would be good.
  3. MikeRP
    MikeRP Supporting Actor
    Aug 8, 2002
    514
    I have the 545.......great amps for the money.
    Mike
  4. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    harman/kardon PA2000 (45W x 4, or 100W x 2 bridged)
  5. Andrew Pezzo
    Mar 17, 2003
    483
    Perfect, excatly what I am looking for.
    Thanks!
  6. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    Andrew:
    You might want to take a look at Harman's EBay store. They auction factory refurbished amps, and there are usually several PA2000's available. They are shipped directly from Harman and carry the full manufacturer's warranty (2 years).
  7. Andrew Pezzo
    Mar 17, 2003
    483
    Thanks Angelo, I just put a bid on one. The problem is I have never seen HK amps in stores before, or Sony ones for that matter, only receivers so I didnt know what was available. This HK PA 2000 seems to be exactly what I need, didnt like I would get so lucky.
  8. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    I don't think h/k amps have been readily available in brick and mortar stores for a while. Circuit City used to carry the PA2000 in their stores, IIRC, and still sells them on-line.
    There is also the PA4000, which is, essentially, two PA2000's in one chassis. I think you'll be happy with this amp.
  9. Drew_W
    Drew_W Screenwriter
    Jul 2, 2003
    1,718
    Parasound makes some ZAMPs as well, which are 2x30 if memory serves, and the unit is quite compact. I've seen them around on eBay/Audiogon.
    You could also get a used Parasound 2x75 (HCA-750A) for a few hundred online used as well if/when they pop up.
    The H/K though is a steal if you can get it for a nice low bid. Too bad harmanaudio won't ship to Canada.
  10. Jimi C
    Jimi C Screenwriter
    Feb 22, 2004
    1,209
    Would the PA2000 be good for powering my mains? Ive been toying with the idea of a seperate amp for my fluance sv10's that im currently running off of my kenwood vr6070. Or if i add this could i use it to bi amp my speakers? using the kenwood and the hk? I think i might be getting in over my head at this point. I dont spend much money so a few times a year i like to splurge on something i dont need. Oh its great being 19 with 90% disposable income.
  11. Andrew Pezzo
    Mar 17, 2003
    483
    What does this stand for, I can never figure it out?
  12. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    IIRC, it means If I Recall Correctly. At least that's what I think. If not, LMK!
    FWIW, that one took me a while to. IMO all these do is confuse people. lol
    It's boring at work today. [​IMG]
  13. Andrew Pezzo
    Mar 17, 2003
    483
