need ideas on hooking VCR ti system
Discussion in 'Home Theater Projects' started by Andrew Pezzo, Jun 11, 2004.
  1. Andrew Pezzo
    Andrew Pezzo Second Unit
    Mar 17, 2003
    483
    It seems I have really confused myself on hooking up a VCR to an audio system. For starters, here is the equipment:
    TV: Mits 48413 (48" RPTV)
    VCR: Sony starndard VCR
    Pre/Pro: Rotel RSP-1068
    Cable Box: Supplied by Comcast, HD capable
    Whats confusing me is the fact that my Mits has a Loop Out and a second input for f-video. I currently have all video running through the 1068 (and I want to leave that way - I prefer only one video connection to TV) and want to use the record out function.
    My goal is be able to record the TV signal. I had it connected in the past with no problems but that was before I got the Mits (which is being delivered tomorrow). Normally I would just run the f-video cable from wall outlet to cable bax to vcr to tv. I would still connect the cable box to 1068 with component video and coaxial for digital audio. The problem is when I did this with my sharp 36 inch tv would get static if the cable box was off. I expected it to work just like a VCR would, it wouldnt have to be on for the TV to still get a signal. Like I said, this connection is just to be able to record TV.
    this post may seem vague, wish I could put it into words better. What are some options?
  2. Scott Merryfield
    Dec 16, 1998
    12,325
    1,073
    9,110
    Here's how I handle this (although I have a DVD recorder instead of a VCR, but the concept is the same):
    1. Split the incoming RG6 cable signal with a 3-1 splitter.
    2. Run one RG6 from the splitter to the antenna input on the TV, one to the cable box, and one to the DVD recorder.
    3. Run the appropriate component, s-video and audio cables from the audio/video components to the receiver (pre/pro, in your case)
    4. Run the appropriate video/audio cables from the TV to the receiver (pre/pro)
    The only thing I cannot do with the above configuration is record from the cable box. However, I do not care about this, since I only use it for HDTV viewing anyway (the standard digital cable channels are of no interest to me), and I have no ability to record HD. If you need to record channels only available via your cable box and your VCR has composite or s-video inputs, you could always loop those and the audio in to the record-out on your pre-pro for that situation.
    This configuration eliminates the need to synch up the channels on the cable box when trying to record on the DVD recorder. I just use the tuner in the DVD recorder.
  3. Andrew Pezzo
    Mar 17, 2003
    483
    Thanks.
