Need Help ?
Discussion in 'Archived Threads 2001-2004' started by Richard Fernandez, Oct 10, 2001.
  1. Richard Fernandez
    Richard Fernandez Stunt Coordinator
    Jul 2, 2000
    116
    Hey,
    Tomorrow is the day I get my television, even though I still can't decide which one to get. It's between the Sony KV27FV17 or the Proton NT-2760. I'm leaning more toward the Sony due to it's 16:9 squeeze. The proton does have it's pros with it's deep rich colors. My question is , does the Sony 16:9 squeeze REALLY make a difference with Anamorphic DVD's. I will be useing BetterCables component cable.
  2. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    The vertical compression will give you 33% more resolution than if the player downconverted...
    It depends on how much better the sony displays the 33% improvement...
    The So Family Home Theater!
    http://www.multimania.com/sonick182/ht/index.html
    You're all entitled to your opinion, but you're all wrong!!! - Paul Dalmine
    ICQ: 8593599
