Matt Kasprzak
Grip
- Apr 27, 1999
Hello all,
I have what appears to be burn in on my TW40X81, however I'm not totally convinced of it. Here's my situation - I would appreciate any input that anyone may have:
- There are three areas, roughly 4-6 inches square, that appear at the very top of the screen.
- The first is about one-third of the way from the left edge, another is about in the middle, and yet another to the right of that.
- These areas show up as brighter and washed out on very dark scenes. (like in Crouching Tiger, Cast Away, others)
- These areas are only visible through the progressive inputs of the TV (either #1 or #2) using my Panasonic RP91.
- These areas are NOT visible through the S-video input of the TV with the RP91.
- I've not been able to detect these brighter areas in the "black bars", rather only the film material (but I need to double-check).
- These brighter areas show up in the 1-2 second delay time prior to the DVD player powering off.
I'm using 3 or 4 meter Acoustic Research Progressive video cables to connect the DVD player to the TV. I'm calibrated with Avia, so no high contrast, brightness issue.
My questions are:
1. It can't be burn in, can it?
2. Has anyone experienced this with either the TV or DVD player mentioned above?
3. Could it be the progressive inputs on the TV?
4. Could it be the progressive output on the DVD?
5. Could it be the cables I'm using?
I need to do some testing with different cables, maybe take my player to a friend's house and try it through their TV's progressive inputs, and try to eliminate one or more of the above. But I'm curious what some of you folks might think just be reading the above, either based on experience or gut feelings.
Any help would be greatly appreciated.
Matt
My questions are:
Matt
