DavidNighorn
- Jun 3, 2003
Hello all,
I have a set of B&W CDM-7 speakers that are giving me a bit of trouble. The problem is that the sweet spot is only 1ft wide. If I am in the center of the sofa, I get a great soundstage and all is well. However, if I move more than 8" to one side or the other, the speaker that I moved toward dominates.
Is this normal behavior? What steps can/should I take to make this work better for me? I am going to attempt to attach a crude bitmap drawing of my room to the next message.
The limitations are that I can only move the speakers 18" further apart and I cannot rotate furniture/locations.
Thank you in advance for your help and advice!
David
David
