Jack Sampson
- Mar 8, 2006
I'm trying to figure out the best way to connect the following devices. Sony 32" tv (1 audio out, 2 video inputs), Dish Network DVR (1 video out), Onkyo TX SR573 Reciver (more input/output connectors than I'll ever need), Sony DVD (Line out). Right now I am using rca type cables on all components. It works but I have to use several different remotes. Also I have to switch input sources from the tv. You have to push a button on the remote called input and it will cycle through vid1, vid2 and I am guessing antenna source. First how can I eliminate the need to cycle through the different sources? And second when I do go to the antenna input the sound is much louder than than the other sources. I want all sources to be loud. Finally I've programmed the different remotes but still don't have all functionality with just one. Is this not acheivable? Thanks for any help....
