Kudret
- Jul 23, 2000
I just bought 2 original SVS drivers and would like to try building my first DIY sub. Here is the sketch of my basement HT room which is 17' wide, 33' long (I am using 18' for HT) and 8' high.
These are the three options that I am considering:
1. There is a 1' wide, 2' deep (and 8' high) space to the right of the RF speaker that I can use to build a sealed enclosure for the two drivers (see the two cirles in the picture).
2. Build a coffee table like sub and put the two drivers in it. Size to be determined.
3. There is a separate storage space, 7' to the right of the RS speaker for an IB type sub. From what I've read though, probably this location is not suitable for IB.
I use my HT for 50% music and 50% movies. If you were in this situation, what would you build? Thanks.
