Kenny Booth
- Feb 19, 2002
Last night I switched on the HT system but I get a garbled picture thru the DVD. By garbled I mean a picture like a cable channel that is blocked. Audio is fine.
Everything worked fine the day before.
I had my DVD player hooked via s-video cable to the AVR--then s-video from AVR to TV. Normal set-up.
I changed the s-video cable and ran straight from DVD to TV.
Now the picture is back to normal. Audio is still fine.
This set-up is ok but the main draw back is that I cannot adjust the AVR because I have no on screen display.
It appears that there is no DVD signal getting from the AVR s-video input to the AVR s-video output. Both s-video cables checked ok.
There was a slight thunder storm that night--so maybe.
Can anyone help?
Can anyone help?
