Need help with a choice
Discussion in 'Archived Threads 2001-2004' started by Ron Kaltenbach, Nov 23, 2002.
  1. Ron Kaltenbach
    Ron Kaltenbach Auditioning
    Nov 15, 2002
    4
    I am looking at 2 yamaha receivers and need some advice and opinions. I am considering the RX-V1 and the RX-V3300. Besides Pro Logic II, the only other difference that has me thinking is that the RX-V1 has DTS ES which uses the Matrix decoder for the rear center channel and the 3300 has DTS 6.1 Discrete. My question is will I notice a big difference with the 6.1 Discrete of the 3300 over the DTS ES of the RX-V1 for the rear center channel when using my DVD player? Thanks in advance.
  2. Khoa Tran
    Khoa Tran Supporting Actor
    Oct 23, 2002
    569
    depends if you have a 7.1 or 6.1 setup
