Need help with 20-39CS
Discussion in 'Archived Threads 2001-2004' started by Conrad_S, Jan 24, 2002.
  1. Conrad_S
    Conrad_S Stunt Coordinator
    Nov 3, 2001
    66
    I'm getting a signal on it, but it is far from the performance I'd expect from it. I've double checked all my wiring, and it looks fine. The Polk PSW450 at half-gain sitting in my room plays substantially louder than the SVS maxed.
    Here's the setup:
    Onkyo TX-DS494
    to
    RCA cable running from sub pre-out
    to
    RCA/.25" mono converter
    to
    Channel 1 on Samson S700 (stereo mode)
    to
    ~ 10 ft. 16 gauge Home Depot speaker wire
    to
    20-39CS (sitting in a corner)
    The room is 12'x14'.
    TIA for any help/suggestions!
  2. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Have you turned the front gain control on the S700 to max?
    TV
  3. Conrad_S
    Nov 3, 2001
    66
    Yes, it's maxed out, but still relatively "quiet". I have to set my receiver's subwoofer level to +12db for the SVS to come close to the Polk at half gain with +2db.
  4. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    Are you calibrating with a SPL meter during all this?
    How large is the room and how far from the SV are you sitting during calibration?
    TV
  5. Conrad_S
    Nov 3, 2001
    66
    No, I have not even started calibrating... At any given volume/setting, the SVS *should* be louder than the PSW450 at the same level, right?
    The room is 12'x14'. *Correction from up top, I'm running 12 gauge to the sub from the Samson.
  6. Conrad_S
    Nov 3, 2001
    66
    I've been going over my components, and perhaps this may be it: (excuse me if I sound like a newbie [​IMG])
    I'm using a "regular" RCA cable rather than a RCA patch cable. Would this make a difference?
    Here's a link to what I'm using:
    http://www.radioshack.com/product.as...5Fid=15%2D1539
  7. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    That shouldn't be enough to attenuate the signal THAT much.
    Make sure there's no compression on.
    Make sure all speakers are set to small.
    Good sub, I have one on 165 watts and there's no comparison to the old box 10" I was using.
    Good Luck!
    - CM
  8. Conrad_S
    Nov 3, 2001
    66
    The receiver has no compression feature, nor does it have the ability to set the regular speakers as small/large. Only the sub can be set to large/small (Mode1/Mode2 in the Onkyo manual).
    It's really weird that this is happening to me, since my brother experienced the same thing when he tested an Ultra. He used completely different equipment, in a different room, on a different circuit. Yet the Ultra experienced similar "attenuation". (Only similarities we shared between the two setups are Home Depot 12 gauge wire and the same apartment.)
  9. ColinM
    Dec 9, 2001
    2,050
    What kind of 1/4"adapter are you using? Stereo or mono?
    Should be mono...
    Otherwise I'm stumped.
    - CM
  10. JohnnyHK
    JohnnyHK Stunt Coordinator
    Jan 14, 2002
    105
    Are you sure it's not just a lack of "boominess" that you're (not) hearing?
  11. Conrad_S
    Nov 3, 2001
    66
  12. Conrad_S
    Nov 3, 2001
    66
    I'm positive it's not boominess. The SVS is just not louder in anyway than the Polk I have in the same room. The Polk has more air movement and is louder - I can't max out the volume on the receiver otherwise I'll get noise complaints.
    The SVS is maxed at +12db on the receiver, I have the amp maxed, and I can turn my receiver to full volume. The SVS just starts reaching my normal listening level for the Polk.
    From everything I've read in these forums, there is no way I should be able to max out the 20-39CS and not be evicted in a few hours... :p
  13. ColinM
    Dec 9, 2001
    2,050
    And when you swap in the Polk, the bass is back?
  14. Conrad_S
    Nov 3, 2001
    66
    That's what I was saying above, I set the Receiver at 0db for the sub. Turn the dial all the way up on the Samson, and the SVS is pretty much quiet.
    I turn off the Samson, unplug the RCA for it from the Sub Pre-Out. Then plug in the RCA for the Polk, which is set at half-gain otherwise it distorts :p. I notice a 2-3x increase in the loudness.
  15. ColinM
    Dec 9, 2001
    2,050
    Sorry, we were posting at the same time.
    Is there a voltage switch on the Sam's power supply? Switched to 220 / 240?
    Ohm switch? I haven't seen the back panel of the Sam before, sorry...
  16. Conrad_S
    Nov 3, 2001
    66
    Here's a link to the user manual/tech sheet on the S700:
    http://www.samsontech.com/audio/sa700.html
    Pretty simple amp, only switches I see are for the Bridged/Stereo/Parallel modes and to reset the 15 amp fuse. The tech sheet has a pic of the back of the unit on the first page.
  17. ColinM
    Dec 9, 2001
    2,050
    If you are daring, try pulling the polk driver and amp the SV with the polk amp...
    Otherwise I'd need to get my hands on it to figure this out.
    Good Luck, man. I love my SV. I hope it works for you.
  18. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    1)Try using the channel #2 input on the S700.
    2)try a different adaptor
    3)try reversing the phase on the SV
    4) make sure all the cables/adaptors are firmly seated.
    5) the onkyo DD receiver should have a menu to set speakers to large/small...subwoofer to yes/no.
    calibrate the SV with a polk off...and post the details on the settings you had to use,and the SPL meter readings... this alone will help us pinpoint the problem much faster,
    TV
  19. Conrad_S
    Nov 3, 2001
    66
    It's late here now, so I'll run through that list after I get back from school tomorrow. I ordered AVIA tonight, so hopefully I'll be able to run the calibration test early next week.
  20. Conrad_S
    Nov 3, 2001
    66
    Had an idea at school, and I wanted to try maxing out the SVS. So, when I got home, I set all the speakers at -12db and the subwoofer at +12db on the Onkyo. Then turned the volume up to 60 of 80... And voila! The SVS was performing at about an awe inspiring 2-3x the level of the Polk. (With distortion, but the +12db was probably the cause)
    Now the question is, how can I get that peformance without having to max the settings out like that? Would something like this do it?
    http://www.partsexpress.com/pe/showd..._ID=5641&DID=7
