Tommy G
- Sep 19, 2000
Jesse and Mark, I thought it might be easier if I copied exactly what comes up when typing in the ipconfig/all. Now, right now I am physically in my company so this might not be correct because I am not using the router right now. I am connected to the network. Let me know if I have to type this while using the router. Anyway, here are the addresses that came up. Thanks so much for helping out. This is such a long process and I can't believe it is this problematic.
F:>ipconfig/all
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : WAL10009710
Primary DNS Suffix . . . . . . . : phcs.com
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : phcs.com
Ethernet adapter {0A43F8BD-8BD4-45FC-ACBE-D7B73AC2447D}:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NOC Extranet Access Adapter
Physical Address. . . . . . . . . : 44-45-53-54-42-00
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 0.0.0.0
Subnet Mask . . . . . . . . . . . : 0.0.0.0
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : 172.16.100.1
172.16.100.2
172.16.100.1
172.16.100.2
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : PHCS.com
Description . . . . . . . . . . . : Intel(R) PRO/100 SP Mobile Combo Ada
pter
Physical Address. . . . . . . . . : 00-03-47-B9-35-B8
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 172.16.96.98
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . : 172.16.1.3
DHCP Server . . . . . . . . . . . : 172.16.100.2
172.16.100.2
Primary WINS Server . . . . . . . : 172.16.100.2
Secondary WINS Server . . . . . . : 172.16.100.1
Lease Obtained. . . . . . . . . . : Thursday, February 27, 2003 7:32:11
AM
Lease Expires . . . . . . . . . . : Sunday, March 02, 2003 7:32:11 AM
F:>
F:>ipconfig/all
172.16.100.2
172.16.100.1
172.16.100.2
pter
172.16.100.2
AM
F:>
