David Dutton
- Oct 23, 2001
I would like to thank all of you who post to this forum for your wonderful insight. I have be reading and learning from your post's the past couple of months and have realized the more I read the larger my budget seemed to grow. My wife thanks you by the way.
So, I have narrowed down the list to the following:
I need a receiver that will allow multi-room, multi component operation. (Marantz 7200,Onkyo 676 or Kenwood 510)
Front Speakers: B&W 603/604 or Paradigm Monitor 7
Center: LCR 6 or Paradigm (forgot #)
Rear B&W 601 or Mini Monitor's (will be on bracket,12'HT.)
Sub: I have a Yamaha SWM 40? Will this work?
The room is 19 x 21 and two stories tall. I am also interested in other options in this price range.
** I do need a receiver for multi-room. I have speakers on the deck and in the dinning room.
Thank you in advance for your help.
David
David
