Need help syncing 2 folders on 2 networked computers
Discussion in 'Computers' started by Luke_Y, Mar 7, 2005.
  1. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Need help syncing 2 folders on 2 networked computers. Both on WinXP Prof.
    My wife is a grad student and has a "School" folder in My Documents on her notebook, and a "School" folder in My Documents on our home PC as well. This folder contains various sub-folders and assorted documents in them.
    The problem is that when she works on one system or the other for a while creating and saving documents as she goes the folders become quite different. She would like to easily keep the folders the same without having to search through both, finding documents and copying them back and forth to sync them.
    Not so much worried about having different versions of docs that are a work in progress, but just having them all available on either computer after they are finished.
  2. Greg*go
    Greg*go Supporting Actor
    Jun 14, 2002
    941
    Have you set up the network to share files yet? If you haven't you can go into the -> control panel -> network connections -> setup home network (located on the left side of the window) and then just go through the wizard. XP is fairly easy to set up, you'll just have to do it with both computers.
  3. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
    My office used to use a freeware program called FileSync for this exact purpose.
  4. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Yes file sharing is enabled... That's not the problem. The trouble is she works on both computers and keeping up with what is where, sorting through dozens of folders, hundreds of files, and copying back and forth every couple of weeks becomes a chore. She want's an easy to keep both folders the same.
    Rob, thanks. I'll look into "FileSync"
  5. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    There is a plethora of options when it comes to syncing files over a normal windows network. One program I've tried and that works well is called Second Copy, but that one isn't free.
    Here's a Google search with tons of links with further info.
    http://www.google.com/search?q=synch...olders+network
  6. Andrew Grall
    Andrew Grall Supporting Actor
    May 17, 1999
    645
    How about syncing files between work and home? Is there freeware to automate this via an ftp site or something?
  7. Colin Davidson
    Colin Davidson Second Unit
    Jan 6, 1999
    403
    30
    Rob -
    Would FileSync work for sync'ing between a PC and USB Jump Drive?
  8. Rob Gardiner
    Feb 15, 2002
    2,950
    We haven't used it for many years, but as far as I remember, FileSync would sync any 2 folders that show up in Windows Explorer, regardless of what type of media they are on.
    FTPSync is available from the same vendor.
