So I pre-wired my sub with the typical 2-wire wires used for all my speakers. Then after drywall was in place I realized my subwoofer takes a regular 1 piece plug (not even sure the proper name for plug) pictured below, however that one is a video connection but it's the same type of connector. My receiver also shares the same connection. In case you're wondering it's a self powered subwoofer.
What are my options to fix this? I was thinking of just buying a compatible wire and cutting and splicing.
