Greg_S_H
I've got an old 98 box that has long had some files I would like to have, but I have never had success with a direct cable transfer. I recently got a Linksys wireless router, so I figured I'd set up a little network and finally get those files. "Wireless" is actually meaningless for this discussion, since I am using ethernet cables for each box, and I seem to have that set up correctly--both boxes have internet access right now.
The problem is, I can see the XP machine from the 98 box, but I can't see the 98 box from the XP machine. In fact, I set up a shared folder on the XP machine just for test purpose, and I was able to grab files from it on the 98. I want to be able to do that on the XP, but when I go to Entire Network, the 98 isn't listed. The workgroup names are the same, the computer names are different, which I believe is okay.
I really don't even know what to do, as the router didn't come with any helpful instructions for setting up a network, and Windows help isn't that helpful. I see a Files and Settings Transfer wizard, but I figure I don't need that if I have a true network. In any case, I have a little trouble there, as it wants me to run the XP CD in both computers. I don't have an XP CD, as it came preloaded. Also, this new computer doesn't have a floppy drive to make a disk. I could burn one, I guess, but I'm thinking this is all barking up the wrong tree anyway. I just want the XP box to be able to see the 98!
Any help?
Any help?
