Need Help setup the 65SWX20B
Discussion in 'Archived Threads 2001-2004' started by Jay JP, Nov 25, 2002.
  1. Jay JP
    Jay JP Auditioning
    Nov 1, 2002
    5
    I have had this set for a couple of days, and having some problems with the picture quality. What is the best setting to watch SD. I have tried all the settings, but usually the picture is good, except when there are peoples faces on the screen. The faces become very spotty and multi-colored.
    Does VirtualHD help with SD. Are there any other setups I should do.
    I am seriously thinking of returning the set.
    --Jay
  2. Dan Ponze
    Dan Ponze Stunt Coordinator
    Sep 2, 2002
    54
    You've done a manual convergence I assume? Also, try to take out some of the red push. I believe there was a post about this a few days ago. That set is fantastic, I'm surprised you're not happy with it but I'm sure it's something that just needs adjustment.
  3. MichaelFusick
    MichaelFusick Second Unit
    Aug 14, 2002
    301
    MOvie mode.
    Sharpness at %30
    Contrast at 60% or less.
    Take off SVM.
  4. MichaelFusick
    Aug 14, 2002
    301
    Let me know if you want more advanced tweaks...
  5. Jay JP
    Jay JP Auditioning
    Nov 1, 2002
    5
    Dan - I have not done the manual convergence yet. Plan to do it today, along with the red push adjustments, which I saw on the avsforum for the XWX. I assume it's the same for the SWX.
    Michael - Let me know what other tweaks I should do.
    Thanks guys.
    --Jay
  6. MichaelFusick
    Aug 14, 2002
    301
    Tweaks are somthing you should learn on your own about first.
    I would:
    -Buy AVIA set up DVD
    -Master picture setting in the user menu
    -Center the screen in the service menu
    -Adjust overscan
    -Touch up geometry and then manually converge via service menu (DCAM MODE)
    -Learn service menu
    -Fix red push and color decoder
    -E and M focus
    -Eyeball greyscale if objectionable (Masters level), or best yet hire ISF guy to come do your greyscale to an Exact D6500K.
    It's about a 6 month learning curve usually, though Sthong on AVS did it all in two weeks then disapeared.
