Tim Knapp
- Feb 18, 2002
Hi,
Need help setting my pc up for HTPC.
I own a intel P3 733 mhz, 512 megs of pc-133 ram, a creative blaster annihilator 2 graphics card- which is a nividia geforce 2 GTS with 32 megs of ram.
I know I need a dvd-rom. (Any particular brand/type)I keep hearing about (all code?)dvd roms.
Is my graphics card adequate for the job? If not what is recommended?
The projector I will be using is a nec lt150z.
Main purpose of htpc is movies. Primarily dvd's but not exclusevly.
Thanks in advance for the help.
Tim Knapp
Tim Knapp
