Need help...Porn site pops up whenever I hit "Enter"
Discussion in 'Computers' started by Jeffrey Noel, Jan 15, 2004.
  1. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    Subject says it all! [​IMG] Whenever I'm surfing the web and I press "Enter", a new window opens with a porn site and is horribly annoying! [​IMG] I'm sure this is some type of Spyware/Adware, but I deleted all cookies that pestscan.com found. However, Pestscan did find the Alexa Exploit on my computer, but I am at a loss to remove it. Could Alexa be the cause of this? If so, how in the heck do I get rid of it. I do not have the slightest clue as to how to edit the Registry files.
    Thanks.
  2. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    We need a sticky for Spybot and Ad-Aware. Install, update and run. If it finds files that can't be removed immediately (because they are in memory) it will let you restart your system and they'll get rid of the spyware before it loads. Good luck. [​IMG]
  3. Neal_C
    Neal_C Second Unit
    Mar 15, 2001
    476
    Definitely get Spybot and AdAware and you can also try Spyware Blaster . It is designed to keep spyware from even being installed on your system. Download all three programs, run spybot and adaware, reboot if necessary, then run Spyware Blaster. It immunizes your system.
    The number of items found with Spybot and Adaware on my system has gone down tremendously since running Spyware Blaster.
    Neal
  4. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    If all else fails, you can run msconfig.exe (from the Run... menu item in the Start Menu, if you have Windows XP or Windows 98). Go to the Startup tab, and select "Disable All", and reboot. If the popups go away, one of the items in the Startup listed in msconfig is launching it. You can use trial and error to narrow it down.
    I used the above technique to fix a company computer, when the latest AdAware (January reference file) didn't do diddily squat.
  5. Todd H
    Todd H Go Dawgs!
    May 27, 1999
    2,219
    121
    1,610
    Georgia
    Todd
    How about a sticky with a link to the Mozilla web browser? [​IMG]
  6. Jeffrey Noel
    Sep 11, 2001
    1,533
    Hmm...I did what Max said...didn't help. [​IMG] I downloaded and ran Spybot and Adaware, they found a lot of things on the computer, but didn't fix the problem. Dag nabbit!
  7. Juan Castillo
    Juan Castillo Second Unit
    Jan 22, 2002
    434
    Jeffrey... what you need to STOP doing, is opening your web browser and typing in a porn sites U.R.L. before hitting enter!
    [​IMG]
  8. Jeffrey Noel
    Sep 11, 2001
    1,533
    Actually, it's my fiance's computer! [​IMG] [​IMG] I've only had access to it for 4 days.
  9. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Did you update Spybot before you ran it? If you did and still no change there's a small chance it's a virus. See if Freescan spots it.
  10. Rob Gardiner
    Rob Gardiner Cinematographer
    Feb 15, 2002
    2,950
  11. Jeff Blair
    Jeff Blair Second Unit
    Apr 30, 2000
    335
    I don't think this will help, but you can get Google's tool bar. It helps stop pop-ups, and it is a nice little add on for IE.
  12. MikeFR
    MikeFR Supporting Actor
    May 16, 2002
    595
    Whats a popup?
  13. Jeff Blair
    Apr 30, 2000
    335
    hehe what's add/spyware/viri??
  14. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    I agree with Max's suggestion on using MSConfig.
    Failing that, try reinstalling Internet Explorer.
  15. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    ummm what windohs version are you running? in your runnig win2000 or xp kill the messenger service [​IMG]
  16. John_Berger
    John_Berger Cinematographer
    Nov 1, 2001
    2,489
    [​IMG]
    Let's create a thread called "What to do if you're having virus or spyware problems with Internet Explorer" and have it sticky.
    Step 1: Download Mozilla
    Step 2: Stop using Internet Explorer which has been proven time and time and time and time again to be the conduit for the majority of these problems, as well as such threads in this forum.
  17. Rob Gillespie
    Aug 17, 1998
    3,632
    5
    That's if you like Mozilla. Or Firebird. Not everyone does.
  18. John_Berger
    Nov 1, 2001
    2,489
    The point is that there are several alternatives out there.
