Need HELP, Pioneer Elite Pro 1000 (1 Viewer)
kopo
JASON
I purchased an Elite pro 1000 2nd hand with out a manual or cables.. I'm looking for information on the type of cables that I need to hook this unit up. It has a strange looking rca type of connections with nipples and also a connection that looks like a computer connection. Jason
Phil Carter
Austin, TX
Phil
The Pioneer Electronics website has all user manuals for their products available for download. I'm not familiar with the Elite Pro 1000 you described but there's a manual for the Pro-1000HD monitor located at
http://www.pioneerelectronics.com/pi...1161147000.pdf
You can also just go to Pioneer USA - Home and click on Support, then find your specific product and pull up the manual that way.
Good luck.
cheers,
Phil
linda19798888
