parin_patel
- Dec 17, 2001
Hi,
I am thinking of putting together a Home Theater system in the next couple of weeks and came across this great forum yesterday. I had initially thought of going with the Sony STR-DE875 receiver, since I've been listening to a STR-DE845 which my friend has for the last year. It seems to be a good receiver (audioreview.com users gave it a pretty good review), has everything I'd want, and seems to go well with the JBL Studio Series (my friend has the Northridege series with the N-center) speakers that I plan to buy.
Then while browsing through this forum, I found that a lot of people seemed to like the Kenwood VR-509 and the Onkyo TX-DS595 receivers. This is what I've been able to figure out so far:
The Kenwood VR-509 (~$299) is 100x5 W/channel, has ProLogic II and component switching with a THD of 0.7%.
The Onkyo TX-DS595 (~$399) is 75x5 W/channel, has Prologic II and high-current amplification with a THD of 0.08%.
Finally, the Sony STR-DE875 (~$299) is 100x5 W/channel and has a dual 32bit DSP (lots of effects) with a THD of 0.09%.
The rest of the features are pretty similar and all 3 receivers fit into my budget. I plan on getting the JBL S312's for the fronts, the JBL S36's for the rear, and the JBL S-Center. I also have a Toshiba 32-inch TV and DVD Player ready to go...
As I said earlier, I have listened to the Sony before with the JBL's and I thought it sounded quite nice. Then again, I am quite a novice with audio and home theater stuff. So do you guys think that the Kenwood and the Onkyo receivers are better then the Sony? Is the Onkyo worth the extra $100? Whatever I get will be a huge improvement to listening to DVD's through the TV Speakers.
Anyway, I would appreciate any help towards making this decision. Hopefully I'll be able to set everything up by the New Year.
Parin
Parin
