Need help on my tempest sonotube pat sun dustin b.
Discussion in 'Archived Threads 2001-2004' started by alan fallert, Aug 16, 2002.
  1. alan fallert
    alan fallert Agent
    May 17, 2002
    30
    Hi guys, I have all of the end caps cut for my 24 inch sonotube,a total of six of them.Im using the tempest driver, and a 6 inch pvc port.I am trying to use pat suns sonotube 2 as a close guide line.Fist of all I am going to put 2 3/4 inch endcaps into the top of the tube, and outside on the top will be a 3/4 inch by 25inch painted black.SO a total of one and a half inches of mdf inside the top of the 24inch sonotube.Bottum end cap will be exacly the same way, a inch and a half of mdf of endcaps inside the tube and one on the out side of the tube so the tube rests on it.. I guess I will tune it to 16.5 hz like pat did.I will put some batting matterial around the inside of the tube about what you did on your sonotube 2 project pat.I have the port cut out just like you did pat with a edge on the bottum endcap it will be resting on, good idea pat.I have a six feet piece of 24 inch sonotube and am ready to cut it. Can you do the figuring for me I dont now how to do it. I would like to keep the tube around 45 inches tall, because i will still have to put legs on it yet. Basicly when it is done with legs and all I would like it around 4 feet, give or take an inch, no big deal.How long does my port have to be to tune it to 16.5hz? thanks all.
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Well assuming your tubes diameter is exactly 24". Which I doubt it is exactly 24". And that your legs will be 4" and the endcaps are another 4.5" that will allow a gross volume of 293L (given a 48" height limit). Net volume will then roughly be 275L. In which case a 23.5" long 6" diameter pvc pipe will tune to 16.5hz or a little lower.
  3. alan fallert
    alan fallert Agent
    May 17, 2002
    30
    Thanks for the quick reply dustin, OK a 23and a half inch long port. But what lenth do I cut the sono tube I have 6 feet of it. Around 44 inches. This way when I put the 4 or 5 inch legs on it I will be at about 4 feet.
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,779
    493
    9,110
    Using 4" legs, you need a sonotube section of 42.5" in length to get to 48" in total height.
    48 - 4 - 0.75 - 0.75 = 42.5"
